Re: Starter Solenoid
Posted by John T on April 28, 2006 at 08:04:58 from (66.244.90.5):
In Reply to: Starter Solenoid posted by Tweeter on April 28, 2006 at 06:21:54:
Tweeter, the answer is YES it could be the starter or solenoid UNLESS its something else lol some help that is huh. Heres my approach: 1) A fully charged 12 volt battery ought to read near 12.6 volts across its terminals sitting there NOT running and around 13 to 14 or a lil over if the charging system is working and shes running at near wide open. If in doubt as to the batterys condition, have a shop Load test it to be sure. Be sure theres electrolyte above all the plates and that no cells have a gray or milky look and give her a good charge or try a know good battery substitute. 2) The next thing I would do is remove, clean n wire brush and reattach each n every battery and starter and solenoid and ground connection. ALL OF THEM including BOTH solenoid connections and the starter connection and the ground connection and BOTH battery terminals!!!!!!!!!!!!!!!! 3) NOW, If the battery is absolutely good,,,,,,,,all cables n grounds n connectiosn are all good (try to reground at a clean main frame bolt if any doubt of ground integrity, especially if shes grounded at a rusty or thin sheet metal seat box or battery compartment etc.),,,,,,,,,but she still occassionally clicks,,,,,,,,its EITHER the starter is going bad (often worn brushes or a pitted burned armature commutator segment) or the solenoid is at fault. 4) If youre careful and have good access to the starter solenoid and starter its possible to try n by pass the solenoid n jump start it by jumping around the solenoid with a jumper cable from the hot side of the solenoid (where big battery cable attaches) over to the starter side or direct to the starters post USE CAUTION THATS A HIGH CURRENT POTENTIALLY ARCING CONNECTION PLUS YOU DONT WANNA ACCIDENTALLY JUMP THE HOT CONNECTION TO FRAME GROUND. You could accomplish the same maybe safer by using one jumper cable to by pass jump over/around the solenoid (jump hot battery cable input terminal over to starter side or starter post) but have her ungrounded and use another jumper cable to make the battery to frame ground connection away from the starter and battery and not near amy source of fuel or escaping battery gasses. OFTEN a solenoid clicking is a sign of a weak battery or a bad connection, so I suspect either of them before a bad starter or a bad solenoid. Check easy simple things first including the battery and allllllllllll connections and ground integrity. Let us know John T
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
