Re: 8 Volt
Posted by RustyFarmall on April 29, 2006 at 07:14:55 from (199.120.81.211):
In Reply to: 8 Volt posted by Tod L on April 29, 2006 at 06:34:50:
I am pretty sure that an 8 volt battery is still available, although your chosen supplier may not have one in stock. Changing the tractor back to a 6 volt would be easier. It is possible that the voltage regulator has been tweaked just a bit in order to keep the 8 volt battery at full charge, but in most cases this was not done. It should be as easy as buying a new 6 volt battery and dropping it in.
