Re: 8 Volt
Posted by John T on April 29, 2006 at 07:52:00 from (66.244.90.5):
In Reply to: 8 Volt posted by Tod L on April 29, 2006 at 06:34:50:
Tod, Im NO fan of the 8 volt system. They are an oddball and the availability of batterys plus how high rated they are is questionable. If one insisit on converting voltages, they ought to go ahead n do it right and convert to the full standard 12 volt system and be done with it. An H ought to start fine with a good 6 volt system so if you wanna stay at 6 I recommend use of the biggest heaviest highest Amp/Hr or CCA battery you can buy that will physcally fit into the compartment. Also I recommend use of 00 gauge Battery n Starter n Ground cables for faster cranking. As far as electrical modifications from 8 back to 6 volts, if it has the simple 2 wire Cutout Relay System or the Voltage Regulator that only had a "current control" relay (2 coil VR) and no voltage controller I DOUBT ANY CHANGES WERE MADE OR ARE NOW NEEDED. However, if it had a Voltage Regulator that had the seperate Voltage Control Relay (often a 3 coil VR) it could have been tweaked up to better charge at 8 volts and may need readjusted. Although it would have been best (to extend point life) I doubt any external ballast resistance was ever added to the coil if its a coil ignition instead of a mag, but if so that would need removed if you go back to 6 volts. Basically, throw in a good heavy duty 6 volt battery and use at least 0 or better yet 00 Gauge Battery n Starter n Ground Cables and no electrical mods are necessary if its a Cutout Relay system and youre off to the races. In the event she cranks slow, I would have the starter tested. John T in Indiana
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
