SC oil leak, belt pulley shaft?
Posted by leon on April 29, 2006 at 17:06:11 from (12.219.19.239):
I've replaced the wear sleeve and seal, but still have an oil leak
when the tractor sets for a while. I'm thinking that the oil
trapped around the belt pulley shaft it isn't draining back. Is
there a drain back hole through the inner bearing web casting,
under the inner belt pulley shaft bearing or does it simply drain
back through the inner bearing, leaving some oil trapped? If so,
what's supposed to keep oil from leaking between the wear
sleeve and shaft? Somebody have one of these opened up and
can look? I'd sure appreciate it.
