Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: H Frozen ?
Posted by Jeff W on January 15, 2000 at 13:40:58 from (4.20.226.204):
In Reply to: Re: Re: Re: Re: H Frozen ? posted by CHO on January 15, 2000 at 10:07:08:
When my H sticks between 2 gears the shifter won't move my little brother has stuck it twice.
He doesn't understand what becareful means I've
run the old gal 5 years and never stick it he's been on it 3 times and stuck it twice, but thats not helping you. You can check your shifter forks by taking of your belt pulley, if you look back into the trans, you'll see 3 little 3/8 X 1/2 in.
squares on top they should all line up in neutral.
Usually with mine I get these lined up and everything goes back it place. If you have to work on theses block your clutch down so the gears can move. Hope this helps, Jeff W. you've got the right man on the job Red seems to know a lot about these tractors, I wish he lived next door.
Post A Followup
: Re: Re: Re: Re: Re: Re: H Frozen ?
