Re: Timing cover seal leak/400
Posted by SDE on April 30, 2006 at 12:48:23 from (69.179.6.135):
In Reply to: Re: Timing cover seal leak/400 posted by El Toro on April 30, 2006 at 06:44:19:
With the tractor in gear, any rotation of the crank would have the potential to move the tractor forward. What do you support the tractor with to prevent it from falling down? That would be as bad as anything that could go wrong. I guess I should try to Make everything more secure. I bolted a piece of channel to the side rail and forward to the bolster. If I did it to both sides I would feel safer. I do have the brakes set also, but they are not very strong.
