Re: F-14 Governor Adjustments.
Posted by Dan in Ore on May 01, 2006 at 03:39:45 from (12.108.20.240):
In Reply to: F-14 Governor Adjustments. posted by BMC-FFA on May 01, 2006 at 03:23:09:
The governor shouldn't need adjusting. Inspect the flyweights and make sure they are free. Check that the springs are not broken or stretched.
Once you get the engine running, check the high speed with a hand-held tach. If it's off quite a bit, then you can adjust the amount of throw to the carburetor linkage. If it's off a little bit just leave it.
