Re: 2-pt 2 bottom plow
Posted by LMack on April 09, 2009 at 20:18:00 from (74.176.38.44):
In Reply to: 2-pt 2 bottom plow posted by Gilbert Dick on April 09, 2009 at 16:17:43:
What are you planning to pull it with? The SC and 200 had a special rod on the left to level up using the touch control to the inside rocker arm. Also, the front of the belly frame had to be extended and attached to the right rocker arm. The left lever controlled pitch and the right controlled front to rear level. All others had more conventional level adjustments. The furrow side point should be a little higher when setting on level ground.
