Re: Rear Hub on 300U,,,,!!STUCK
Posted by Szrachnor on May 10, 2006 at 07:31:08 from (68.118.182.183):
In Reply to: Rear Hub on 300U,,,,!!STUCK posted by biggerred on May 10, 2006 at 06:21:05:
I've heated a lot of those hubs and others on other tractors will no negative effect. I usually do not have to heat them red hot though. Here is my technique, but if your not planning on ever doing this again it may be cheaper to take it to a machine shop: I put an OTC 1130 bearing splitter on the hub and pull on it with an OTC 938 17&1/2 Ton Push-Puller. Jack both sides of the rear end up and put jack stands under each axle housing. Rotate hub and gently start heating (kinda sounds like dinner). As the hub heats up add pressure to the push-puller. ALWAYS STAND TO THE SIDE OF THE HUB! When it comes off it will come off with a pop and some force. If you trust yourself enough you can use the tractor's own power in first gear to rotate the hub for you, BUT make sure the tractor is jacked, blocked and properly secured first. Otherwise, have somebody spin the other tire, your hub should rotate in the opposite direction for you. If you already haven't gotten the broken bolt out, use left hand drills to drill it. If the bolt isn't bottomed out, all the torque was released when the head broke off and sometimes left hand drills will catch the broken part and unscrew it for you. If not use easy-outs after drilling. Szrachnor
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
