Re: Stipping down an M...again
Posted by Janicholson on May 11, 2006 at 06:08:25 from (66.173.50.109):
In Reply to: Re: Stipping down an M...again posted by Turbos10 on May 11, 2006 at 05:51:28:
THe steering rack needs to be from a car/truck with the tierods on the same side (front or rear) of the axle as the system you build. If not it steers backwards. (I helped a neighbor keep from making that mistake once).
The pump is driven by a slotted coupling (look within the last few pages for trans oil seal replacement discussion and pics) the drive hub id grooved, the driven has a rib that fits into it. Remove the thin cover to see it directly. They slip apart along the drive slot, so it needs to be turned vertical. Clutch down in neutral allows free turning by hand. I hope this helps.
JimN
