M Lift-All
Posted by JimCEMA on May 11, 2006 at 09:09:58 from (143.232.166.55):
I have an M with a lift all. I want to use it with some newer equipment with hyd cylinders that I also use with newer tractors which run Hy-tran hyd fluid.
Can I run Hy-Tran hyd fluid in a lift-all instead of the recommended 30W motor oil?
Anyone done this? Problems?
Thanks
