Re: Bolt holes on new manifold much larger
Posted by DCW on May 11, 2006 at 18:12:37 from (156.34.196.161):
In Reply to: Re: Bolt holes on new manifold much larger posted by djp on May 11, 2006 at 17:51:54:
That would make sense.My tractor was a kerosene tractor originally,the casting code on my head has it cast in 1948,which means the low compression kerosene head was replaced,hence the bigger studs.That is one of the very few castings that isn't original.You should still be OK,use hardened flat washers and lock nuts on it,if you feel keeping it tight is a problem.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
