Re: stuck M piston frustration
Posted by Nat 2 on May 12, 2006 at 05:07:08 from (64.80.110.33):
In Reply to: stuck M piston frustration posted by sccwells on May 11, 2006 at 20:40:46:
NOBODY told you to use anything steel to pound out the pistons! Steel is BAD. If the pin slips when you hit it, steel will tear holes in the block that cannot be repaired. Instead of a rebuildable core, you will have a hunk of useless scrap iron.
At this point, you need to concentrate on driving the sleeve out of the engine, not the piston. All that work you're doing on the piston is just a waste of time; you're making holes in the TOP of the piston. The sides are still intact, and firmly rusted to the sides of the sleeves.
