Re: How might you do it?
Posted by JT on May 12, 2006 at 11:58:56 from (70.226.203.104):
In Reply to: Re: How might you do it? posted by werger on May 12, 2006 at 09:09:07:
If you want nothing but the tractor to run, hook one wire up to the hot side of the battery, to the switch, then from the switch to the hot side of the coil, this will give you juice to the distributor to make it run. Nothing will charge thsi way, but it will start and run your tractor this way.
Jim
