Re: 1066 injector pump
Posted by IaGary on May 12, 2006 at 14:59:00 from (69.63.16.227):
In Reply to: 1066 injector pump posted by ih544D on May 12, 2006 at 11:54:29:
If its where mine was its under the aluminium cap that is held on with 4, 1/4" bolts.
The screw has a slot in the end and has a 7/16 jam nut.
Each turn out will make quite a change in raising hp.
Gary
