Re: Switching to a 12 volt Delco Remy Generator
Posted by Easy on May 12, 2006 at 18:01:31 from (69.216.128.60):
In Reply to: Re: Switching to a 12 volt Delco Remy Generator posted by Nebraska Cowman on May 12, 2006 at 15:32:29:
I did the same thing. The generator puts out volts. If you check it across the fields on the gen, before the regulator, it might be 20 + volts. Put a 12 volt regulator on it. You do need to reverse the polarity - the instructions come with the regulator. The starter will be fine.
