Re: 12 volt alternerator for 1940 Farmall?
Posted by F-Dean on May 12, 2006 at 18:43:14 from (67.72.98.83):
In Reply to: 12 volt alternerator for 1940 Farmall? posted by CrazyCooter on May 12, 2006 at 13:42:21:
BIG JOHN has been putting a Hitachi #14231 alternator on several tractors in place of a generator under the hood.
This alternator was used on 1978-79 Nissan 620 pickup with a 2 liter engine and a 1980 Nissan 720 pickup with a 2 liter engine. At NAPA it is part #2138130. The cost of a rebuilt alternator is approximately $50 + core (And they won’t take a generator as a core).
The alternator is 4 1/2" in diameter and 7" in length and will go right on the original mountings on the tractor. Use an 8" x 3/8" bolt and some pipe for spacers. Being Hitachi means that it is METRIC. You will need to drill out the mountings to 3/8". The tension adjusting bolt is also metric thread.
The alternator is a three (3) wire set up which can be converted to one (1) wire. There are spade connections labeled S & L and a BAT post connection. The L spade is for the idiot light and can be disregarded. Use a jumper wire from the S spade to the BAT post and you are good to go.
The pulley may be a split type that you can widen using a spacer (once again metric). You will need to use a disc type lock washer and some “Locktite” because there won't be room to reuse the split lock washer that comes with it. I put the washer between to parts of the pulley to make it fit the existing belt.
There is a built in regulator and a resister to keep the battery from feeding back to the alternator.
This is a sweet fit under the hood that he has used on H's, M's and W models, also Cubs and many others.
I add the following from my experience:
Be sure to switch the polarity of the battery to Negative ground to avoid damaging the Alternator.
Consequently, you need to switch the wires on the coil, if you are using a coil.
Use a plastic covered connection when you connect the jumper wire from the S spade
On a Farmall M, turning the bracket upside-down will allow the alternator to fit nicely inside the hood using the existing generator belt.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
