Re: Messed up Radiator Mount on H, how to fix it..
Posted by Janicholson on May 13, 2006 at 07:32:08 from (66.173.50.123):
In Reply to: Re: Messed up Radiator Mount on H, how to fix it.. posted by Michael Soldan on May 13, 2006 at 06:53:01:
Michael is on track. If you are a good solderer you might try it yourself. The key is clean, cool, and fast. Clean everything till bright. Position the stud plate and wedge it in place so it cannot move easily when bumped. (I use pieces of broken brick to do this because they do not melt/burn, and they do not suck up heat. Place the bracket so that it is upside down and kinda level to make the solder flow flat, not vertical. Pack soaking rags in the back of the hole, and around the sides of the bracket and hole (this keeps the heat from traveling to the radiators solder joints, which you do not want to melt). Use a soldering iron that is flame heated copper tipped, or an electric iron in the 450 watt+ range. get it well pre-heated befor starting. Use 60/40 tin lead acid core solder. Apply the heat to the thickest parts at the joint first, the heat will transfer to the thin areas easily. Pre-coating the joint with flux is ok also, but use acid core solder. After the solder runs in and fills the gaps, clean off the flux with solvent to keep corrosion away. If the above is not comfortable to you, or you are not a solderer, follow Michael's advice! Let us know what happens, JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
