Re: farmall 656 wiring
Posted by Allan In NE on May 13, 2006 at 09:36:02 from (148.78.243.24):
In Reply to: farmall 656 wiring posted by charleskirton on May 13, 2006 at 09:27:00:
Charles,
I can't make out your diagram, however, sounds like you are needing a circuit from the ignition switch's "ignition" termainal to the positive side of the coil; thru a resistor if necessary.
Your tractor is starting and running on the starter's ignition feed at present.
Allan
