Re: farmall 656 wiring
Posted by the tractor vet on May 13, 2006 at 09:42:46 from (64.179.117.21):
In Reply to: farmall 656 wiring posted by charleskirton on May 13, 2006 at 09:27:00:
Sounds like your missing the hot wire from the key switch to the resistor if it is a gasser as there should be juice to the resistor as soon as the key is turned on the juice that you are getting to the coil is from the start side of the seloniod for the HOT START and nothing for the run . Get your test lite and start checking . Off the top of my head at the moment i can not remember the wire color for the key to coil .
