Re: stalled international 300 utility
Posted by El Toro on May 13, 2006 at 10:43:23 from (64.12.116.65):
In Reply to: stalled international 300 utility posted by bob young on May 13, 2006 at 08:28:22:
I would pull the plugs to be on the safe side. Then see if the engine will crank. If that starter has a solenoid it could be the problem too. Make sure your tractor is out of gear and take a flat blade screwdriver and short across the small terminals on the solenoid. It should crank. If it doesn't pull the starter and connect it to a battery. Then short across the small terminals to see if the starter drive (bendix) flies forward. Just touch these terminals to see that. Keep your hand or fingers away from that end of the starter. Hal
