Re: 656 main bearing seals
Posted by River Bottom Farmer on May 13, 2006 at 10:55:51 from (205.188.116.133):
In Reply to: 656 main bearing seals posted by IndianaMike on May 13, 2006 at 09:49:25:
It probably can be done in frame but from what you are saying I would pull the engine and get the crank out and get it checked out.You may need to get it turned and get oversizes bearings.Just trying new bearings is an expensive failure if the crank is damage or just worn down too far.Just trying to help.....RBF
