Re: fan pulley on H
Posted by Haas on May 13, 2006 at 17:34:50 from (12.65.42.165):
In Reply to: fan pulley on H posted by KRUSS on May 13, 2006 at 08:18:07:
You do not have to take the water pump off to replace the broken sheave. You do have to take the bearings assembly off, but you can leave the pump housing that contains the impeller on the tractor. Remove the fan drive assembly(the thing with the springs on the front), the fan and the packing nut. Then remove the clamp nut that holds the bearing assembly. Then the bearings and all will slide off, but the water pump housing will still be mounted to the engine. The rear flange of the pulley is pinned to the bearing housing assembly. It's a chore to get the pin out and that rear part of the sheave off, but even more of a chore to get it back on and aligned so you can get the pin back in. I ended up taking mine to a shop to get help in getting it back on. I got the pin out on my own. The hole for the pin is not straight, so you will need to put a piece of 1/8 inch round stock in the hole to see where to position the sheave half when you put it back on. While you have tha thing apart, check the bearings for play and you might as well put in new grease seals and get some shaft packing too and add a ring or two of packing.
Home
| Forums
Today's Featured Article -
Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
