Re: md
Posted by Brad in WI on May 13, 2006 at 23:00:35 from (24.208.55.96):
In Reply to: md posted by mi mark on May 13, 2006 at 18:35:31:
With the excessive smoke when switching over to diesel, that could be caused by faulty injectors or injection pump. On the gas side do you have to choke it to start, did you try to clean the carb, if it is possible to do a compression test see what it comes out to be on the gas side and that will be a good indication if a rebuild is in your near future. It should have around 100-125 PSI all even across the board if the engine is in good shape. Anything less than 90 PSI I would say time to get down and dirty and order some new parts. My .02 cents on the matter.
Brad
