Re: Farmall A Fan Hub
Posted by Red Dave on May 14, 2006 at 16:40:34 from (66.109.236.136):
In Reply to: Re: Farmall A Fan Hub posted by gene bender on May 14, 2006 at 16:11:28:
gene, I would like to try 2-12's, I have plenty of power, it's traction I usually run short of.
An older fellow here helped me out with the plow set-up and adjustments. It's pulling pretty nice now, but it's been so dry the ground is hard as a rock!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
