Hyd coupler on M hyd pump
Posted by jjam on May 16, 2006 at 16:00:05 from (68.217.184.66):
What is the best way to get the coupler off the Trans. driven pump on an M Farmall? My book says to put a steel rod in the gears and hit the coupler with a brass rod, hammer ect. I tried that and the only thing i have done is chip the gears. Is the coupler threaded on the shaft or what? The only thing wrong with the pump is the seal needs repaced.
