Re: Farmall Oil Press. Gauge..
Posted by Dave BN on May 17, 2006 at 13:05:22 from (66.255.198.240):
In Reply to: Farmall Oil Press. Gauge.. posted by Stan(PA) on May 17, 2006 at 12:28:55:
I don't know the answer to your question, but most of the older tractors run on the low side unless they have been recently overhauled. You could most likely improve your oil pressure by rebuilding your oil pump. I put a new bottom plate, pressure bypass spring and plunger in my BN and it made a big difference. The bottom plate is expensive ($100 or so) and you may be able to hone your old one and reuse it. Dave
