Re: Farmall Oil Press. Gauge..
Posted by chadd on May 17, 2006 at 13:29:38 from (155.92.31.62):
In Reply to: Farmall Oil Press. Gauge.. posted by Stan(PA) on May 17, 2006 at 12:28:55:
This might be a dumb question, but are you sure you are looking at the oil pressure gauge? To me, it sounds like you are looking at the coolant temperature gauge. The oil pressure gauge, if original, should only have the word oil in the center and a red zone on the left and white zone right of the red zone. The dealer replacements have numbers instead of colored zones. Assuming that the two gauges have the same insides with a different face, the right end of the red zone would be 75 psi. All the way to the left would be zero. Correct me if I am wrong about this, as I have never seen a green, white, and red oil pressure gauge before.
