Re: Stiff brake/clutch pedal on Farmall A
Posted by Hugh MacKay on May 17, 2006 at 16:44:37 from (209.226.106.129):
In Reply to: Stiff brake/clutch pedal on Farmall A posted by Thomas Minter on May 17, 2006 at 11:13:24:
Thomas: It's time you had a manual. In the Farmall 130 manual it is on page 38, illustrtion 38E. The same diagram is in every manual for A, SA, 100, 130 and 140. It shows 4 grease fittings on the clutch and brake pedals shaft, one at each brake pedal, one where clutch pedal turns on brake shaft and the 4 one where brake shaft comes out the left side. That is exactly how every offset Farmall from 1939 to 1979 was equiped.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
