Re: Farmall Oil Press. Gauge..
Posted by captaink on May 17, 2006 at 17:37:34 from (66.115.214.56):
In Reply to: Farmall Oil Press. Gauge.. posted by Stan(PA) on May 17, 2006 at 12:28:55:
I’d just like to add to the other good comments is that the A has the thermo-siphon cooling system. If this system is plugged or not cooling correctly and you have light oil in it that could result in lower than normal oil pressure. You might want to give the cooling system an once-over while your checking out the other ideas.
