Re: Farmall A Zenith carb - which kit?
Posted by CNKS on May 17, 2006 at 17:50:27 from (204.249.178.138):
In Reply to: Farmall A Zenith carb - which kit? posted by Larry Ed on May 17, 2006 at 15:09:32:
For the Super A (I assume the A is the same, but you better check) there are two Zenith carbs. A 67x7, IH distillate number 357156R91, and a 161x7, IH 48616 DC. The latter is the one used on the early Super A's so it is more likely the one you have, UNLESS it has been changed. Where the throttle body attaches to the bowl on the 161x7 the gasket, bowl,and throttle are round in front of the place where the venturi is. The same parts on a 67x7 has an extension in front of the venturi. The air intake on the 161x7 has a smaller diameter than the 67x7 and the connecting hose to the air cleaner butts up against a lip on the carb. The 67x7's air intake is smooth and does not have the lip. My recommendation is if you have a nearby Case-IH dealer, to take the carb, or at least the bowl gasket and have him look it up. Or, call Carter and Gruenewald, 866-327-6255, and have them send you one. Unless you can tell VB for sure which one you have.
