Re: Clean hys sys on 300u
Posted by Janicholson on May 17, 2006 at 20:01:20 from (66.173.50.165):
In Reply to: Clean hys sys on 300u posted by Jimer on May 17, 2006 at 15:44:50:
If you replaced the fluid, it is probably OK. Using an aftermarket high flow filter in the return line to the pump can catch material before it gets into the pump. Flow should be 16GPM or so to reduce restriction on the intake. Taking it all apart, sucking out fluid and cleaning the bottom of the resivoir is another option, if you are rreeaall serious.
JimN
