Re: 300 PTO adjustments
Posted by Unreserved dick on May 18, 2006 at 01:38:46 from (4.228.126.72):
In Reply to: Re: 300 PTO adjustments posted by Wes in Ohio on May 17, 2006 at 20:38:09:
Actually Wes has it backwards: the top (forward) band is the PTO drive, the bottom (rear) is the brake. The screws in the photo look as though they're screwed in just about as far as they'll go, so it's probable this unit needs new bands. Big thing on the adjustment is to make sure (engine off) that the PTO shaft rotates freely with the control lever more-or-less in the middle postition -- I like to adjust it so that the drive band is a bit tighter (shaft rotates freely with the lever about 1/3 of its travel up from the braking position). This helps prevent the drive band from slipping under heavy load. Best technique I've found is to turn the individual screws in until the shaft won't rotate properly, then turn that screw back out just enough to allow the shaft to turn properly (lever in middle position). This is a fussy adjustment at best, and worn bands make it worse. Take your time and good luck. The adjustment is described pretty well in the Operators Manual which is well worth having.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
