Re: 300U Coil?
Posted by jeffcat on May 18, 2006 at 08:33:26 from (216.107.36.86):
In Reply to: 300U Coil? posted by Gus on May 17, 2006 at 17:30:33:
That coil can be a real doooozzzeeyy! Found out when plowing when it would sputter a couple of times and then puke out. See if is hot. I do mean HOT to the touch. As had been said, check the screen in line where the tube goes into the carb. Remove the little plug on the bottom of the carb and drain out any crud. Have fun! jeffcat
