Re: 1950 C MODEL
Posted by Jim Becker on May 18, 2006 at 10:25:07 from (71.96.7.230):
In Reply to: 1950 C MODEL posted by JEFF RICKARD on May 18, 2006 at 08:49:12:
Since you didn't say what you are doing, it is hard to say what you are doing wrong. Only thing I can say for sure is you have your Caps Lock turned on.
The usual way to bleed air out of the system is to top off the reservoir, and cycle the system back and forth a bunch of times (may help to leave the fill plug out). Shut it off with the levers in the rear positon and top off the reservoir again. If it takes any amount of oil, repeat until it stabilizes.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
