Re: B Overheating???
Posted by glennster on May 18, 2006 at 14:12:33 from (68.77.132.76):
In Reply to: B Overheating??? posted by jenglin on May 18, 2006 at 10:15:31:
the b has a thermosiphon non pressurized cooling system. there is no water pump. i have a b with a 5 ft woods belly mower. it will occasionally boil over if you are moving sideways on a ditch. seems like a slug of air gets up in the head and then burps out. try flushing the cooling system. any auto parts store sells a cleaner you pour in the radiatior and let it idle for 15 min or so to get all the rust and lime out. i have been using distilled water with the antifreeze instead of tap water to cut down on the lime build up.
