Re: SMTA - weak Hydraulic lift and noisy Live PTO
Posted by Bob M on May 18, 2006 at 15:19:59 from (69.205.125.67):
In Reply to: SMTA - weak Hydraulic lift and noisy Live PTO posted by Walter in Ky on May 18, 2006 at 14:23:25:
Walter - Check to make sure the Liftall control rod (the one that works the lever on the right side of the hydraulic reservoir) is pulled back FULLY and latched. If it is not you can get weak hydraulic action - or no action at all.
Sorry....I have no experience with SMTA LPTO problems...
