Re: 1066 TA getting weak?
Posted by the tractor vet on May 18, 2006 at 16:15:45 from (66.202.111.205):
In Reply to: 1066 TA getting weak? posted by Wicksfield on May 18, 2006 at 06:45:27:
Well first ya need to make sure that the shift valve is going all the up and all the way down . Then ya need to do a clutch adjustment , dump valve adjustment and a transbrake adjustment , then ya need to put the gauges to it to see what ya have for pressures , the one you can do if ya have a 600 lb gauge and the fitting the other pressure test ya have to have the special test spool and that is something that not many have . If it is grabing on the low side with out stopping then the T/A is not out . Also you are not shifting to the high side fast enough , shift it like your mad at it . If you want more info let me know as i guess i am the local GURU on the newer stuff.
