Re: 300 Utility hyd help
Posted by TDK on May 18, 2006 at 21:13:23 from (152.163.100.65):
In Reply to: 300 Utility hyd help posted by MJF on May 17, 2006 at 18:17:14:
I can't answer about the loader, but the rear lift has a check valve to hold it up. It's located on the bottom of the valve that operates the lift(rear valve). These sometimes allow the lift to leak down whan they get some debris inside which holds a valve open.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
