Farmall Tractors Discussion Board
Re: Re: Re: Re: H Transmission Plug
Posted by The Red on January 16, 2000 at 13:01:53 from (12.75.47.176):
In Reply to: Re: Re: Re: H Transmission Plug posted by Greg on January 16, 2000 at 12:58:18:
Those vary slightly from H to H. It may take one inch stock. You can also use a wide chisel and insert from corner to corner. You risk breaking the chisel if the nut is really in tight.
Post A Followup
: Re: Re: Re: Re: Re: H Transmission Plug
