Re: 826 Hydrostat
Posted by Allan In NE on May 19, 2006 at 05:36:09 from (148.78.243.24):
In Reply to: 826 Hydrostat posted by Dan-IA on May 18, 2006 at 18:45:22:
Hi Dan,
It shouldn't "coast to a stop". That function is controlled by the anti-coast valve and is located in up the control manifold. A lot of guys call these two valves "capsules". Takes about 3 minutes to swap 'em out.
Don't worry about the "clutch". All it is, is a "dump to sump" needle and seat, which empties the line pressure. Just don't see how you can hurt it by using the clutch.
Hope ya get 'er figured out,
Allan
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
