Re: Emblems/Nameplates 100 Series
Posted by Nat 2 on May 19, 2006 at 21:09:45 from (24.93.8.168):
In Reply to: Emblems/Nameplates 100 Series posted by Grandpop NY on May 19, 2006 at 19:35:55:
Depending on what part of NY you're in, if there's a Valu Home Center near you, you can get the clips that push over the pins there.
If the actual pins are missing from the back of the emblem, then just use stainless steel sheet metal screws, available at Lowe's, to screw the emblems on. The pins can't be replaced, or "glued" back on.
