Re: IH 756 stuck in forward or reverse
Posted by the tractor vet on May 20, 2006 at 06:43:40 from (66.202.111.63):
In Reply to: IH 756 stuck in forward or reverse posted by John25 in MO on May 19, 2006 at 21:10:58:
Not only do you have to have the free travel set correctly but also the T/A dump valve and transmission brake . Now if ya do not know what i am talkeing about then i would suggest that you get and I T manual and read up on what is what you you know what i am talken about and also make sure that the oil lite comes on in the dash as this will need to be working . After ya know where the dump valve is and transmission brake are i will walk you thru the propper way of doing it as i have a way of doing it that works real well and no silly massuren to do that nobody ever gets wright . the only place that you have to use a massuren stick is for the free travel of the clutch , myself i made up a go nogo block that i use for the )6 seires and one for the 56' and also the 66's that way ya just slide it in and adjust and you are there. . When the adjustments are correct they will shift with two fingers .
