Re: M - Carb help
Posted by DJL on May 20, 2006 at 17:13:43 from (70.106.253.222):
In Reply to: M - Carb help posted by DJL on May 20, 2006 at 16:13:43:
Thanks Cowman! Went out to the garage, and with a little carb cleaner and a rag, there it was, just where you said. Thanks for the photo and help.
Here's the next question: On the carb that I took off, the tag reads 50983DC. On the rebuilt carbs here on YT, there's 3 choices. The closest choice says it replaces 50983DB. Do you know what the difference between DB and DC are? Will this one work?
Thanks
DJL
