Re: Timimg mark On c169
Posted by El Toro on May 21, 2006 at 07:55:12 from (152.163.100.65):
In Reply to: Timimg mark On c169 posted by Rick/Oasis ID on May 20, 2006 at 19:33:49:
Bring No1 piston to TDC on the compression stroke.
Then look at your rotor, it should now be at the No1 plug tower. Your timing mark on your pulley should be near or at the pointer. Hal
