Re: Adjusting Timing on an M
Posted by Bob M on May 21, 2006 at 09:49:56 from (69.205.125.67):
In Reply to: Adjusting Timing on an M posted by turbos10 on May 21, 2006 at 09:03:23:
Chris - The stock distributor M is equipped with centrifugal (mechanical) advance. I'm not certain but recall something like 0 deg at low idle to a max of 35 deg at 1,100 RPM and above.
If you want retard the spark simply rotate the distributor body ONE HALF the number of degrees of retard you desire, rotating it in the direction of dist rotor rotation (clockwise for an M...)
