Re: OS-6 shifter
Posted by Rags on May 21, 2006 at 11:07:40 from (65.140.207.192):
In Reply to: Re: OS-6 shifter posted by Rags on May 19, 2006 at 13:33:09:
Hello Jim!
The tractor is on rubber & it has a hand clutch which is on the right side when seated on the teactor.This is a narrow tractor which was mostly used in vinyards.Very much like the 0-6 but without the sheet metal that covered the wheels,engine & etc.There were only 731 of these tractors made.I assume they were all five speeds.(Don`t know).Thanks for responding. Don.
