Re: Farmall H 6 Volt Voltage Regulator - Resistor
Posted by Bob M on May 21, 2006 at 13:03:51 from (69.205.125.67):
In Reply to: Farmall H 6 Volt Voltage Regulator - Resistor on F posted by Ed McCullough on May 21, 2006 at 12:19:10:
My recomendation is to purchase a new regulator. If the resistor on the old one has gone bad chances are good it has other problems too (or soon will have problems...)
If you replace the 4 terminal regulator with a 3 terminal, simply connect the wire that went to the "L" terminal on the old regulator to the "B" (or "BAT") terminal on the new one. (You"ll now have 2 wires on the new regulator "B" terminal...)
