Re: Farmall H Rear Rims...36 inch not 38??
Posted by RustyFarmall on May 22, 2006 at 04:52:25 from (199.120.81.254):
In Reply to: Farmall H Rear Rims...36 inch not 38?? posted by JoeFarmall4182 on May 22, 2006 at 04:36:07:
Some of the early Hs and Ms did come on 36 inch rubber. If you look through an original parts manual for these tractors you will find that there are many, many, options, several different configurations of steel wheels and quite a few options on rubber tires. Most of us consider the 38 inch rear tires to be standard, but when you study the subject in depth you will find that there is no such thing as standard.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
