McCormick 45 Baler, looking for parts
Posted by Mike S806/H on May 22, 2006 at 18:25:46 from (68.188.233.243):
I looking for a some parts for a 45 baler, part numbers 495 181 R3, gear/drive/auger, and 495 162 R2 ,pinion, auger drive gear, mine are wore real bad but still works, would like to have some good used or nos parts, Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
